Front Mud flaps
14 replies [Last post]
In an effort to get rid of the mud speed stripes appearing down the doors and mud encased steps I would like to fit mud flaps to the front of my 463 G300 SWB.
But I can't work out what they would fix to. There doesn't appear to be any kind of bracket in situ and it's not obvious (to me anyway) where such a bracket would fix, assuming that a bracket is needed and available.
Anyone know the answer please?
Re: Front Mud flaps
You can get that flexible plastic from Demon Tweeks etc aimed at the Rally Brigade, expensive for what it is but very light, you could cut to size and use self tapping screws on the plastic wheel arch liner?
Re: Front Mud flaps
Ah - does that mean that they were never designed to have front mud flaps?
Re: Front Mud flaps
Most of the mud flap kits I have seen for the front of G Wagons are designed to fit onto the side steps. The rear ones seem to be just a set of rubber flaps fitted with self tappers screwed into the wheel arch.
http://www.ebay.co.uk/itm/162076180712?clk_rvr_id=1152735712216&rmvSB=true
Re: Front Mud flaps
Rear ones have expensive brackets that eventually rust away, thought rear mud flaps a legal requirement? Front ones, sure Gav will correct me but not from factory for uk? The demon Tweeks stuff works ok but maybe doesn't look great
Re: Front Mud flaps
"thought rear mud flaps a legal requirement?"
That made me think so looked at lots of G55s and G63s for sale on Autotrader and vast majority didn't seem to have front or rear mud flaps fitted.
Re: Front Mud flaps
Not up on newer G's, maybe they modified them with something subtle moulded into the bumper? Wouldn't like to be following one on a rainy day!
Theo
Theo's picture
Re: Front Mud flaps
they are available from Mercedes, code P47 (front) P48 (back);  picture shows a 461 but if I'm not mistaken they could be ordered for the 463 as well.
mgrays
mgrays's picture
Re: Front Mud flaps
I have rears on a 460 and yes.. the steel brackets have been rebuilt a few times. They look silly as they are set for non arched wheels as standard and I have never re-engineered the brackets out to match the wheels. A pain to remove/fit!
I have a set of MB fronts sitting on the shelf. I never did work out how the brackets fitted. I now have wheel arch liners and it gets even harder. So .. I do not know how they fitted.. and as the G has not moved in 2 years on the road as it has stopped snowing.. well other projects get in the way!
GermanStar
GermanStar's picture
Re: Front Mud flaps
Where to get this front mud flaps?
Re: Front Mud flaps
Depends on what model G you have.
I just got a set from MB but they are for a 463 without MB sidesteps. I understand that these will not fit if you have factory fitted sidesteps.
As it is, I'm struggling to work out how these fit to mine.
GermanStar
Re: Front Mud flaps
These from first picture. Where to get them?
Re: Front Mud flaps
My 463 had factory-fitted from mud-flaps, but I had to remove them to install the side-steps.They were attached to a bracket that clamps onto the longitudinal  under-body, seam
LEONIDAS
LEONIDAS's picture
Re: Front Mud flaps
Hi Mark
In case you are still looking for this, I bought a couple of years ago the  front set which is described as follows:
MA463 880 03 22 SPLASH GUARD    PRICE  £32.21 EACH x 2
MA 463 880 0093  N/STOCK CLIP       PRICE 25.13  EACH  x 2
They are very easy to fit and you do not any side steps for this, as same are secured directly on the  car body and can form a continuation of the wheel arch liner
Re: Front Mud flaps
Many thanks Leonidas.
I've already purchased a pair but so far haven't been able to fit them. I've had a look but can't work out where the bracing strip and clip actually fit. The obvious place is the "lip" at the bottom of the wing but not sure that's right as the black clip would be visible against the silver bodywork.
Probably have another go when I get the chance.
