Exhaust system 320 CDI
Does the original exhaust on your G require replacing already? What year is yours?
Any vehicle built after sept 2001 requires a factory approved cat, homogolated is the word used I think. And probably you have a diesel particle filter too. The risk with going to non MB products is that the steel may be cheap and rust. Mind you the MB system doesn't seem to have lasted very long.
I can't think that there is any difference in the exhaust between LHD and RHD but who knows.
I know that you said that you didn't want to get one made but I have just used Stainless Exhaust near Manfield to build a system for my G and it is excellent. Life time guarantee for a lot less than MB prices
Eberspacher is the OEM .
Look them up. They also sell aftermarket.
PM me your VIN with a list of the parts (complete) what you need!!!
and i will see what i can do
and i will send you the quote
discount on OEM parts direct from factory (GRAZ)
ADRIAN
GOOD GOD thought it was a bit of pipe
all prices incl tax & bank
as there is enough parts to build a battle ship
i have sent you a PM with my email address so you can send pics of the stuff you need
(10) 4634907214 catalysator 1000 euro DEL uk
(20) 2194920080 flange gasket 11 euro DEL wk 4/16
(30) 0009906703 X3 screw 2.5 euro on stock
(40) 0004920881 seal ring 8.5 euro wk 4/16
(50) 2024900641 clamp 40 euro wk 4/16
(60) 9101430090-06 screw 2 euro on stock
(70) 4634907414 catalyst 2,130 euro wk 4/16
(80) 0004901541 pipe clamp 16 euro wk 4/16
(90) 4634900992 particle filter 2,070 euro wk 4/16
(100) 4634902001 EX MUFF CENTER 370 euro on stock
(110) 1264920581 x4 seal ring 6.5 euro on stock
(120) 3040170080-53 X4 screw 3 euro on stock
(130) 9101130080-02 X4 nut 1 euro on stock
(140) 4634900721 exhaust pipe 190 euro on stock
OPTION
(150) 0035427018 travel sensor 300 euro on stock
(160) 4634900039 delivery line 275 euro on stock
(170) 0009054305 temp sensor 105 euro wk 4/16
(180) 0009059005 temp sensor 105 euro wk 4/16
HEAT PROTECTION
(10) 4634921230 heat shield 32 euro on stock
(20) 4634925730 heat shield 35 euro wk 5/16
(30) 4634926630 heat shield 60 euro wk 5/16
(40) 4634925830 heat shield 45 euro wk 5/16
(50) 4634926530 heat shield 8.5 euro wk 5/16
(60) 4634924530 heat shield 45 euro wk 5/16
(70) 4636824471 heat shield 60 euro wk 7 /16
(80) 4636802620 heat shield 170 euro wk 7/16
(90) 4634920130 heat shield 70 euro on stock
(100) 4634921130 heat shield 16 euro on stock
