Exhaust
9 replies [Last post]
Freddie
Freddie's picture
Dear All,
I have a 1999 G 500 and i have been told that i need to replace the two silencers that are on the L/H side of the G, just wondering if i should replace the entire exhaust with Merc parts or take the SS route or just replace the two fauly parts, any advice would be appreciated
Kind regards
Freddie
Re: Exhaust
I've no experience of the V8 but in my experience of the 6 cylinder petrol you will save money by going stainless and you may be able to delete one or more of the unessecary silencers
Re: Exhaust
It would be worth getting a quote from a local stainless steel exhaust fabricator to compare with the MB replacement price especially if you plan to keep your G for some time.
Don't rush into deleting silencer boxes. I had a stainless system made for my GEL300 and thought it would be a good idea to modify the system so it didn't have to cross over the rear. I reduced it to feeding into one long silencer on the drivers side and then exiting on the same side instead of feeding into another two silencers and exiting on the passenger side (RHD Vehicle).
The result was a lovely deep growl which was very satisfying when sitting stationary blipping the throttle. Definetly not so satisfying when cruising along at anything over 40mph with a constant roar of exhaust behind your right ear. I can say from experience that MB knew what they were doing when they designed the exhaust system.
Here is a schematic of a 2002 G500 exhaust system in case you dont have one.
Re: Exhaust
If you had two smaller silencer boxes where you mow have one, Doug you wouldn't have that problem, or just keeping the small central box and losing the huge final one. I had this done on a ge280 long b4 I had my GE300
Re: Exhaust
The essence in the question is why are the exhaust in need of replacement, if there are blows which are beyond economical patch repairs that's fair comment, if however the comment was made cause the outter skin is shabby looking then you have more life from the system then made out to be. I have noted that the outter skin and mounting brackets fair worse than the inner skin so as long as you have no leaks then you should be O.K., but take note this as to mean that you are now saving a budget for the job.
Idea of comparing costs of the whole system, part system from M/Benz and a Stainless Steel version is worthy exercise.
Also a system that has last you some 19 years is not bad going.
Freddie
Freddie's picture
Re: Exhaust
Hi All,
Many thanks for your replies, the need to replace the two silencers is because there is a rattle coming from inside the boxes and the garage tell me that there are fins inside that have come loose? i hope this makes sence any more  advice would be appreciated
Freddie
Re: Exhaust
Freddie.
Before doing anything else, make doubly sure that it really is the exhaust that's the problem.
Does it rattle when the car is standing still or only when you're moving along?
A while ago I was convinced that my exhaust (that's on a G300 SWB not a G500 but even so). The garage put it up on the lft and checked all the supports, brackets etc. but couldn't locate the exact problem. Then they checked the rear shock absorbers and springs and "assumed" that one of the shocks had gone.
I almost pushed the BUY button on purchasing a set of shocks and springs but then had a lightbulb moment. I wedged a bit of towel in the rear door, drove the car along potholed road and - NO rattle.
I replaced the plastic door supports (MB price £45) and cleaned and greased the locating hole above the top hinge and all is now well. Close to £1,000 saved.
If it is the silencer boxes, think long and hard about replacing with "nice throaty sporty" boxes. They might sound great to start with but they can become really annoying/draining after a few hundred miles on the motorway.
Re: Exhaust
Yes, Loose baffles make sense, then your exhaust renewal is justified.
Freddie
Freddie's picture
Re: Exhaust
Hi All
Thanks for the advice so far, I’ve now been told that it the cat that needs replacing what would  be the best route aftermarket replacement or a full SS system
Regards freddie
Simon666
Simon666's picture
Re: Exhaust
Hi. I got mine made from the cats back in stainless steel (fully fabricated inc silencers) for circa £700 fitted and at their recommendation deleted the box that sits between the chassis frame (they said it would reduce vibration/resonance that can come with SS exhausts) and shortened the others and went side exit. Gives a muted burble that will turn into quite a howl above 4,000rpm - but not intrusive into the cabin. The only thing to watch is the exhaust banging on the ladder frame where it crosses over when you go over bumps. I had my entire system sized up pipe diameter wise and occasionally get a thunk out of it even though they but heat resistant rubber on the frame. You may well find all the heat shields are knackered as well. One of mine fell off and is now being followed by one of the others. The upside of losing them is your undersea storage can be used to heat food on journeys :-) Best
