Engine won't turn off
My 230GE won't turn off consistently with the key. Sometimes it does, sometimes not. Sometimes it does with an engine rev while turning the key, sometimes not. I've swapped out the ignition key assembly, no change. I've inspected for vacuum leaks and can't identify any. What else controls the off of the engine?
Check the Vaccum from behind the Key barrel, I'm sure theres one there. i think
I had a similar problem with my old G350td.
Preety sure its a dodgy or cracked rubber pipe either in engine bay!
Diesels will do this, but petrols (230 GE ?) shouldn't unless ignition switch or relay is faulty
Sorry thought it was diesel....
Hello,
I have wiring diagrams for the W463, but unfortunately, not the W460. However, it's bound to be similar to a 230E saloon from that era. Try Google Images and search for "230E Ignition wiring".
There appears to be an engine control module. perhaps this is faulty?
Sorry, I can't be of more help on this.
No worries Gooch. Thanks for offering up some advise.
