Engine swap!
Ahoy-hoy!
So, I got an offer from a guy saying he would swap my OM616 with an OM617 88hp. He offered to just keep my gear box on since it apparently fits right on the new engine.
Is there anything in particular I should check about the engine or my own car before going forward? Is it worth the £1000 he´s letting me pay for it?
This guy is an experienced mechanic from the Danish army so I´m not worried about his skills.
I like the OM617 - very reliable engine. However, some might say that it's not powerful enough. If the replacement 617 is a known good engine and is included in the price, it would seem a fair price for the work. I would think that the swap should be very straight-forward.
I would take the time to to a top-end overhaul with at least new valve seals. Also, change the engine mounts whilst at it.
Yes, that would not be a straight drop-in replacement. However, I think that G-Restorations could advise on your options.
i think the auto-box is a great companion to the standard 617, which I've also driven at 80 (just about) on European motorways. The auto-box allows faster get-aways without losing momentum with manual gear-changes, so it can be quite quick at roundabouts, traffic lights and about town. Ultimately, more power is always desirable, but the 617 auto combination is not bad at all. In fact, on a 460 cabrio, even possible to spin the rear wheels.
I'd second the suggestion for injector overhaul and valve-clearance-check .... and polish of valve/cam cover.
Sorry, by 'auto-box', I meant automatic gearbox. Autos go very well with diesels, though you might lose a smidgen on economy. It's a personal choice, but I would probably prefer it to a 5-speed manual. The 460, 300GD Auto cabrio now spends all of its time in the mountains in Italy, 50% of the time on dirt tracks so perhaps the standard 617 is a good choice, then. I didn't imagine that the turbo version would have reduced, low-speed torque, but I guess MB must have made the right choice when fitting non-turbo, Diesel, engines for military vehicles. I notice also that the new military Gs are now all (?) automatics - at least in the brochures.
DK the 617 will do you fine SWB rag top will go OK
as said the 617a is UNDELIVERABLE with out
having the IP mod but thats about 400ukp
then it will pull like a train from 1000rpm
not so bad with manual gear box as you can slip the clutch
but with automatic you are in top gear at 28 mph
' In-Line Pump' ??
Injection Pump
you are right almost every thing is automatic even the big
6x6 pinzgauers i know the off road boys say manual is the way to go
my pal said that to the factory test drivers on the schockl
so they took him in a 4x4 pinz it was over 45deg steep over rocks
then asked him to change down a gear WOW only the test driver was laughing
my mate was white as a sheet as they sped back down backwards
then the took the 6x6 pinz easy peezy kick down and up she went
and with the G you can lock it in any gear
for me no option with a club foot just glad it works for me
The correct automatic box rather than a manual is in my opinion the much better option for offroading.
1) It allows for constant progress without any loss of momentum due to changing gear.
2) It allows for very slow speeds when negotiating obstacles without the need to constantly slip the clutch.
3) It allows the vehicle to stop on hill ascents without the risk of stalling.
4) It allows both hands to stay on the wheel to help with steering.
5) It eliminates the possibility of missing a gear or selecting the wrong gear. If you have ever selected third gear instead of first when about to descend a steep slippery slope you will know exactly what I mean .
Driving a manual in extreme off road conditions definitely requires more skill than driving an auto but I wouldn't say that it is better than an auto.
Not sure what you mean by' hard to regulate precisely', do you mean because you can't slip the clutch in an auto ?
Ref Auto Vs Manual - as you say personal pref, and I suspect things have moved on... But if you've a got a bit of time on your hands :-) Harald Pietschmann has a few views on the subject: http://www.4x4abc.com/4WD101/index.html I found it an interesting read. Remember to look though his links about styles & tips etc. I suspect I'll never get to the outer edge of the off-road envelope so for us mortals it will always be about what we like to drive - but a good read! Thanks Simon
I would put your engine up for sale here, german ebay and other european sites
Thanks for your thoughts Arnie.
Yeah, from what I´ve heard it really is a very strong and durable engine. I was actually looking for an OM602 which is what our army 290GD are using and I really like the way they drive and handle. That´s a bigger project of course and I don´t know how difficult it would be to put one of those in my 240. Would need a new gear box as well of course.
