Engine mounts W463 300D LWB manual left hand drive
Hi everyone, my engine mounts appear to have failed. There is much more vibration and noise in the cabin and a clank when i turn her off. Can anyone advise me what my options are please? Genuine mounts appear to be very pricey. Are there any other alternatives i can use please? Thanks
You could try adapting engine mounts from any of the Land Rover/ Rang Rover models - it would be a matter of fittings or having brackets fabricated to fit; this has been practiced by some in particular the few who are into engine conversions.
me
No way do you need to use Landrover mounts, three are chesper options
PM me
I have some good sec hand ones, cheap if you interested
Can't remember but think according to the workshop manual, sure someone else will advise, you are meant to compress mount in a vice with central bolt loose, then tighten bolt when it under compression, but possible if yours are original they just knackered? Only want post for mine, as they not mint but certainly useable.
This can be used as an option.....
Look at this on eBay http://www.ebay.co.uk/itm/390973020979
I think the mounts are fluid-filled, which contributes to the damping, so they should be replaced with the same types for best results. Febi are an aftermarket spares company and their source of parts is variable, you may be lucky with them... or not.
