ECU W463 270CDI
Sat, 10/05/2014 - 19:27
Do any of you know where the ECU is located on a G270CDI?
I am doing the EGR mod, but it is a different location than on the ML.
Regards
Sat, 10/05/2014 - 19:58
Re: ECU W463 270CDI
If its a 463 series G270CDI it would appear the Engine ECU (CR) is located on the right side of the transmission tunnel up behind the centre console? It slots into a bracket screwed to the tunnel... you are looking for an ECU numbered A612 153 xx 79 usually a silver box 160mm x 160mm x 40mm approx
Hope that helps..
If not can you PM or post up the Chassis Number etc
