Door Locks
Mon, 23/01/2017 - 01:01
Hi All,
I have a problem with my central locking the near side rear door only opens about 20% of the time any ideas why this is happening
Regards
Freddie
Mon, 23/01/2017 - 13:39
Re: Door Locks
You might try removing the door card and squooshing any connections with magic WD40 while also checking that they are properly plugged in to each other.
It did the trick on my 1988 460.
Good luck.
Nick.
Sun, 05/02/2017 - 00:05
#2
Re: Door Locks
if you are referring to when you put your key in the driver's door that the other door locks don't operate, then it's a problem with the microswitch in the driver's door lock that does not signal the other locks to open. Some contact cleaner / WD40 may help.
