diffs
I have posted many times on my g wagon issues and rebuilds
All is well but i thought some axles i purchased from Canada need fitting for a taller top gear
Had them in garage for a couple of years and one of my rebuilt axles became noisey 30k after rebuild???
Its seen a lot of off road but what killed it was cheap bearings. I contacted my bearing supplier and he told me they were chinese bearings. I did not reply as i thought my friend had got them from someone else
He said he only would sell me the best bearings and never that make as they never stock them ever
Lesson to be had is dont believe all people say
Got timken bearings for diff rebuild off my supplier as he says they are the best for the sizes i require. Cheaper total cost than other bearing friend lol
To the point
Got pss wet through 3 nights in a row
swapped diffs and all seems ok
I did get sick of it as it was for a trial and i did think why am i doing this??
I posted before that i achieved 40 mpg but that was very careful cruising at about 54 mph
Truth is i went a long run most of the time at 80 ish and i got a super 20 mpg
So a time for taller gears
Bodged it and did job asap. Tightened pinion bearings too much i feel but its mid limit on mercedes spec sheet
Removed complete hubs and calipers and discs but what a weight to maul back in so not to damage swivel seal
Tried it and done 50 miles with no leaks
40 is now 50 50 is now 62 and 70 is now 73.85 mph
I actually use first
All good and i will let you know if anything keels over
Also i will let you know fuel economy as i have a run planned soon
The last run was 600 miles at 20mpg as i said
The gearing is better but people either put their foot down and it cant pull the ratio so drink fuel or they run at high revs using fuel
I like it to be overgeared as you can always downshift
Keep you posted
Im sure pinion bearings will get warm at those settings but if it all lives and no issues i dont care
I am looking at selling it and getting a unimog
Any unimog experts out there please contact me
G
I forgot to say i want a rhd
But send me some info and a price as a friend also is looking at them
Just a quick description with the main points and i will pass it to him
Regards Gaz
