Diesel fuel pipe from tank to engine
Fri, 04/08/2023 - 11:41
Does anyone know where I can buy a replacement pipe? Mine has corroded.
It bends around the bottom of the car so I guess it needs to be mailable?
Sat, 05/08/2023 - 11:42
Re: Diesel fuel pipe from tank to engine
The dealer if you want to keep it all original, or if you don't mind, you can use nylon tube like new cars use. Easy to work with and low cost.
https://www.advancedfluidsolutions.co.uk/8mm-od-x-6mm-id-metric-nylon-pa...
Note that this is just the first web page that came up, you can probably buy cheaper elsewhere.
I have used this before, both on my Diesel W460 and on other petrol cars.
Thankyou
