463 gearbox problems
Sun, 06/09/2015 - 21:16
I'm having major woes with my autogearbox in my 606 conversion. I have been doing some light driving off road switching between low and high ratio. Car now won't go into reverse. Cant select low/ high(unless I stop the engine) and overheated the box fluid. I think it's died but am more worried about the transfer box.
Will the centre difflock work if the reservoir is completely empty? Any ideas on what's up?
Sun, 06/09/2015 - 22:08
Re: 463 gearbox problems
Can't help with the gearbox. The centre diff lock doesn't use fluid to operate, only vacuum.
My old auto G didn't like changing from H to L when stationary if the engine was running as there is still torque being transferred
Mon, 14/09/2015 - 22:35
#3
Sorry to hear that. However, I can only add, once you have the newer 5-speed box fitted, it will drive much better than mated to an older 4-speed version.....your mileage will also improve markedly as the 'overdrive' gear is much smoother for motorway cruising. Good luck/ph
Mon, 14/09/2015 - 23:08
#4
http://ofgear.dk/ .They show his brothers G350 with the kit fitted. Worth the hassle I hope.
Looks like I'm going for a newer 5 speed auto...it's a bit of a project but shouldn't be as bad as a 606 swap. I think the 606 power,240k miles and high rpm on the motorway finally killed it. Here's a link to the ecu that I'm using Speak to Mark Ashton about these controllers, three years and I think 4 Gs he's given up on them and gone to Six speed manual
Gordon
