463 fuse box mystery
Sun, 17/05/2020 - 10:01
This is minor but a mystery to me.
My door sill illumination, driver side, never worked, so I wanted to check the fuses which on a G 463 are scattered in 3 places.
In the easy to get to drivers side fuse box I have the sort of fuses that should be for courtesy lights and also the optional door sill light.
According to other online sources it should be fuse #26.
But my 2012 G350 Bluetec looks like the attached - fuses 1-10 and 11-18. Nothing like the diagrams I have seen and no sign of a fuse allocation chart anywhere.
I know it's not a fuse issue though, because the passenger side dill is working, and it's not a split fusing. I hoped it was just a led bulb, but the bulb is not accessible. It's built into the stainless sill which just pops on and off. Don't tell me I have to buy a complete sill to fix it!
Wed, 20/05/2020 - 21:06
#2
Re: 463 fuse box mystery
Cant you take it to a friendly bodyshop to ask advice about removal? Even Dacia now has illuminated sills, so possibly a repair is straightforward? Can you swap with a rear one? On my early 463, that piece of plastic easy to remove, just using fingers.
