463 Diff Lock Relays,
Help my diff locks all failed, or no yellow power lights. No power at back of switch . Fuses fine. I think I have narrowed it down to a failed relay,Relay is 2nd from the left , part no 003 545 33. 05. With a normal relay I get power to the switches. Though diffs won't engage. Unsure how many relays are involved in diff locks, at least 3?
Is the above relay only made by MB? As they not cheap £110 ish.
I don't remember exactly what these look like, but most of the relays have removable plastic covers. You could try to open one and see whether the problem is a soldering failure, which is sometimes the case.
(PM sent)
Yes, I guess it would need to be a special to combine all the functions into one relay. Does it have 3 sets of contacts - one for each diff-lock ?
By the look of the whitish patches, the circuit board may have suffered from some water ingress. if you have a fine soldering iron, the circuit tracks can be repaired with thin copper wire.
Would this help Jason ?
Although the part number appears to be referred to as a throttle/kick down relay ?
Looks normal, but unfortunately very exclusive
