460 vehicle 463 rear Cill and quarters ?
ive be sent 460 panels I ordered from MB but notice rear tailgate Cill and passenger side rear quarter light cluster are marked with 463 numbers,is this correct ? Attached photos of panels in question I do have 463 light clusters so handy to use panel to accommodate these thanks in advance
Passenger side (RHD) rear quarter last year was part no 460 647 33 07 I think the cut out for the lights is different on 463 from 460.
Not sure if the sill is the same for a 460/463
Not holding a shot gun to my head but I think the rear quarter panel is the right fitting for a W463. The W460 lens fittings has four nodules near the screw fittings to locate the lens cluster in position.
I cannot speak for the sill panel.
Suggest your get another dealer to check these number for you; if you ask for the number they will not give it to you just be straight with them mentioning that you have an order from another dealer and wish to double check the part numbers for correct supply - have your chassis number at hand.
Rear Door lower Cill panel is good, 460 supersedes to 463 as both really the same
460 and 463 rear lamp panels are different completely
They will fit the truck other than rear lights are different size and obviously right 460 has filler aperture and 463 doesn't
I must confirm it is a Swb 230ge 1989 year 460 model I'm fixing :-)
