460 to 463 Radiator conversion
Hello fellow members, I can now offer a kit to easily convert the 460 to have a 463 radiator fitted (aluminium part no. 463 500 11 00). The kit includes bottom and top brackets, all rubber mounts needed, bottom clips, all bolts/nuts/washers, a template to modify the top cross member and some instructions. Price is $250 plus any shipping (usd). Please PM me if interested. Scott
Not to be seen and known as a "kill joy" but what are the advantages of this conversion? Why fit in an over engineered (over engineered in the sense the W463 radiator has in built engine and gear box oil coolers) part to one that is perfectly designed for the purpose unless the W460 radiators are not available?
Other than that Good Luck with Regards.
Yes that makes sense - totally skipped my mind on that one.
Thanks for the reply.
Hiya
Would you mind please posting a few photos of what they look like?
im keen to change mine for a bigger one in thr hope to keep it cooler.
I have pinged Stig an email. He hasn't been active on here for a while. Lets see.
Sound advise from Nick. Just giving the cooling system a flush and using a descalent would be a good start.
and checking the pump and thermostat.
HI Chaps, I have done a full flush, I ran clean water thrugh it for hours until it was clear, recore was done by one of the guys that owned it before, that said i have not looked and changed the thermostat so i think il do that next. That said, id still like a bigger rediator if anyone is reading this.
anyone got a part number for the 463 rad
