460 280ge Turning over the engine
I have recently acquired a 280ge which has been sat for around 17 years. Before changing fluids I am doing a compression test.
I removed the spark plugs and disconnected the HT leads at the distributor, as well as removing the fuel pump relay from the fuse box under steering wheel and connected the battery from my other car. Turned ignition on and tried to crank and all I got was starter motor wheeze.
I didn't get a multimeter on the starter motor or hit it with a hammer, first I wanted to check I could turn the engine over by hand.
I have downloaded a pdf of the workshop manual but it is a scan and not easily searched
The Problem
I've had a feel and I don't think there's an exposed crankshaft bolt on the crankshaft pulley. It doesn't seem very Mercedes but it does appear to me that I'm going to have to remove the crankshaft pulley to get to the bolt. To remove this pulley, since I can't see a tensioner I must have to remove the power steering and alternator pulleys first? (Non-AC model)
If anyone could give some advice on getting to the crankshaft pulley that would be great!
You seem to be doing all the right things, but surely hitting the starter with a hammer is the first course of action, then all the rest can be avoided (if it can free up the engager). You will have to sort that sometime.
I can tell you the firing order on the 280 is 1-5-3-6-2-4
0.8mm on the spark plug gap.
The Operating manual has 1 picture of the pulley, and no nut. There is one on the power steering pump though if your belts are still on.
lol. thats funny.
but good news so far. I don't think that 'lower' compression will matter too much for petrol engine, though it does indicate wear somewhere. But that engine has sat for years, so you should repeat once running properly.
Now you know its not seized.
Back to the firing sequence. I don't see how the distributor can be connected in anything other than the specified sequence.
RESULT.
Keep it going. people always want to see the journey. High pressure fuel lines are cheap to replace (braided rubber ones) and one thing that duct tape (or amalgating tape!) wont solve for any length of time.
Presumably there is more serious issues with the tranny, if engine running OK. But they are normally bullet proof. See how you get on, but a replacement might be the way to go if you hit trouble.
I am having minor issues with my KeJetronic fuel injection - all to do with ensuring you have fuel pressue (control and delivery) and no vacuum leaks anywhere. Its running great at the moment though. Hopefully yours is good enough but after all that time stood the things that go are: fuel pump (easy to tell), fuel acumulator (mine was gone and caused poor start), [both up on the ladder chassis behind the nearside rear wheel, UK] and Idle Control Valve (mine is OK, possibly). Also the fuel pressure regulator on the side of the meter head (not checked).
Obviously change the fuel filter.
Where in the world are you?
280 Starters are prone to oil ingress from leaks and are getting hard to find, overhaul of your unit is probably the best solution
M110's also like to stick Exhaust Valves when stood a while and I guess 17 years will pass that level easily ;0)
May well come back ok when running and warm
Good luck!
I think the clue is in:
I think m102 and m103 engines got KE Jetronic, but the older m110 unit was a more basic K-jet
You are looking at the Fuel Filter and the Fuel Accumulator (keep fuel line pressurised). On the ladder chassis behind the nearside rear wheel (UK).
I think your fuel pump relay sounds bad. I had to replace mine (well I had it replaced, not me). Don't wire the fuel pump direct (some muppet had done that on my 230). Because (a) the pump runs nonstop and (b) its dangerous in an accident.
The Accumulator only needs replacing if you have a bad start condition (cold or hot). The Fuel filter is a given, especially after a long lay up (which also kills the accumulator diaphram)
See the attachment here. Its a good overview of all the fueling components.
HAHA Mark .. not that slow.. yet!
FPR do go bad... two types and you can hard wire 2 pins for test purposes think 13/87 but quick google will tell you
Should also have early type overload protection relay that Fuel circuit runs thru so check fuse in top of that and relay also
Make sure all fuses are good and then check contacts and then check again!
Make sure you squeeze each one in gently to make sure it grips the fuse properly
Hi and thanks for the reply. I will hit the starter later and see what happens, I just wanted to sanity check it wasn't pushing against a seized engine - although I'm doubtful the starter motor would be strong enough to do any damage to the timing chain etc I didn't want to find out the hard way if indeed my engine were seized.
Thanks for the timing order, I did in fact see this on the valve cover which I thought was a nice touch -> when I traced the HT leads back to the distributor I noted that the leads were not in any (anti)/clockwise firing order on the distributor. This I did find a little surprising given that when i took the distributor cap off it looks like a device that rotates the point of contact to initiate firing -> it seems wrong that this distributor wouldn't have been set up in a 1-5-3-6-2-4 sequence. A trivial point for now though while I work on cranking but it's something I might need to check at some point.
My main question to your response would be; is turning the power steering pump going to give enough friction on the belt to turn the engine also? Or is the belt likely to slip on crankshaft? It shouldn't cause any harm to try either way
I will also check spark gapping before reinserting so thanks for the gaps too. I have a funny feeling that I will be discovering that the head gasket has gone -> there is a large oil stain on the front left (if looking from radiatior, also RHD side) at the top of the block, and when I went to remove the spark plugs I noticed that the central two cam cover bolts were finger tight so someone has clearly been here before me. I was told by the previous owner that it was parked up because of either a transmisison problem or transfer box issue.
